I tried something new ...
Gonzo
... this weekend. Washed with NXT shampoo, wet clayed, washed again with NXT shampoo, AIO'ed and, for the first time, put a layer of EX-P on the wife's new CRV - pewter metallic. It came out extremely shiney and slick. Needless to say she was happy with it.
Now some noob EX-P questions.
a) Was the AIO step necessary? It didn't seem to "hurt" the final results.
b) Can layers of EX-P be built up or will it clean itself off? Will SG adhere to EX-P? Can EX-P layer over SG.
c) Any studies done comparing longevity of EX-P with, say the K twins?
Great shine and slickness approaching UPP - I like it so far.
If there was any "downside", applying with a damp 4" foamie, it was hard to get a thin layer, because after a while the foamie seemed to "clog up some" and didn't want to suck up any more water - which I got around by wetting the back side, but even this didn't appear especially effective. Any "thinning" advice would be appreciated (you know, like applying AIO with a foamie primed with EO W&S)
Thanks
You found EX-P to be slick? Many people including myself find EX-P to be lacking in the slickness department. The little slickness it does have disappears after the first wash.
There are many comments about it's lack of durability. EX-P was undetectable on my car after one wash. I was very disappionted in the durability. Comparing it to Klasse SG for durability? No contest, they are not even close.
Was AIO necessary? I don't know the condition of the paint before you applied EX-P. If it needed a good cleaning than AIO is a great choice. I'm not aware of any product that AIO is not a good base for.
Is EX-P layerable? IMO no. When I use it on single stage paint it removes a lot of paint. My app looks like it does when I use a pre cleaner, a lot of paint transfer. I don't see how you can layer a product that does this.
There is a new EX-P. I think it's called EX-P Plus or something. It might be better than the original version.
c) Any studies done comparing longevity of EX-P with, say the K twins?..........
If there was any "downside", applying with a damp 4" foamie, it was hard to get a thin layer, because after a while the foamie seemed to "clog up some" and didn't want to suck up any more water - which I got around by wetting the back side, but even this didn't appear especially effective. Any "thinning" advice would be appreciated (you know, like applying AIO with a foamie primed with EO W&S)......
A. As Stevet mentioned AIO is a good cleaner/prep for almost any product, just depends on the condition of your paint. I like VM (Vanilla Moose) as a prep for EX-P also.
B. I usually apply a second layer to at least help ensure complete coverage (wait 12-24 hours). Some have reported that EX-P does layer, while Stevet's experience on SS paint would dispute that claim. Stevet, did you notice paint transfer on a 2nd coat after the first one cured (just curious)?
I don't know about putting SG over EX-P, I don't think I would. I have read where some believe UPP (sealant) bonds over SG, but I have not personally topped a sealer with a sealer. I often top sealers with a carnauba, but once that is done a sealer will not bond.
C. SG will last longer than the current version of EX-P, especially when you put on more than one coat of SG. There is a newer version called EX-P+ that is supposed to have more gloss and last longer. I believe it will be released sometime this spring (I have a sample but weather hasn't given me a chance to try it out yet).
The first time I applied EX-P I used a damp foam pad like you used, but I think it would have been easier using a pad such as this:
http://www.autopia-carcare.com/vk-101.html
Since then I always apply with the PC and a finish pad because I find it much easier to apply a thin coat that way. I just mist it with a little distilled water before application. HTH
Yes, I did have paint transfer when I applied a second coat over a cured first coat.
Also had paint transfer when I applied EX-P over cured SG on single stage paint.
BTW I was using Megs foam apps for application.
Poorboy's is comming out with EX-P+ because the original EX-P is lacking in many areas compared to other sealants.
Not very slick.
IMO can't be layered.
Terrible beading. Sheets water. This might be a positive depending how you look at it.
Not very durable.
Not very slick.
Not very durable.
I have had the total opposite with ex-p. :nixweiss
EX-P Rocks IMO
Great on glass, quite layerable and a EXP & Wolfgang combo is killer.
Agree with you about slickness though. That's where WG comes in
In most cases I top an acrylic sealant such as SG with a super or regular polymer sealant
UPP after SG is another of my favourites
Since clay removes polymer sealants when your removing fallout etc, I always try and convince my customers into having their car's paint klassed.
Hope EXP + is a step up in quality
Will experiment with FMJ and other sealants too.
Of course there are some regular polymer sealants that can't be layered.
