EXPDetailing
I scored some cast aluminum, painted & clear coated wheels for the winter time off of a Town & Country that were heavily corroded (I don`t see wheels this bad too often) with brake dust. Strong, potent wheel cleaners, color-changing wheel cleaners had a hard time with the mess, so I turned to Flitz Instant Remover, and it worked so much better than the expensive stuff, however, the fumes are almost unbearable. The wheels actually came clean. I thought they wouldn`t because the expensive stuff didn`t come through. If you use this method, you will have to pull your shirt over your mouth and nose. Flitz had no adverse reactions to the painted surface.
I wouldn`t use this method, unless I had too.
Just thought I would share, in case, if you`re ever in a pinch.
Sorry, I didn`t take pictures.
