I have seen some excellent tutorals and tips on restoring wheels on the foum but not on hub caps.
I have some 90 (Buick Reatta) caps that the clear coat needs to be removed, the cap metal (aluminum) condiditoned, and then refinished. The caps have a glued on plastic logo center.
The caps or metal part of the cap have very faint circular lines and although a shinny clearcoat, it is not reflective (probably because of the circular lines). The center has to be protected/taped as it is the logo encased in plastic.
I have previously experimented with different grades of wet or dry paper (sanding in a circular motion around the metal part of the cap), and different semi gloss clear coats, and can't seem to get it right or close to OEM...any suggestions please :help: ?
thanks,
Nic
thanks,
Nic
