how to use P21S Paintwork Cleanser?
CGdetailing
do i use a black or blue pad and then work it in like a polish until it dimishes? Or i use it like a sealant then wipe it off with a mf towel? thx. :rockon
I'd go with the white unless you have a near pristine surface. You could go over it a second time with the black if you were wanting to try polishing it a bit finer. (Just to be sure, your black pad is a very fine, smooth pad, right? At one time there was a black pad that was the most aggressive pad (more than yellow) and I would not recommend using it after a white pad.)
