How To Remove Swirls From Swirl-a-Matic Car Wash.....
dengelson
What do you use for trouble spots like tar, insects, bird bombs and unknown road spuge?
I learned something new yesterday. I got home after a nice drive and noticed a dime sized bird bomb on the passenger side. I used Meguiar's FI to moisten then wiped the offensive little turd off of my black paint. Uh, oh... although the offending bird bomb was only on the paint for a couple of hours it left a dull spot in the finish where it had been.
First I tried the simple approach of waxing the spot after QDing. Wrong, and I already knew this too, wax will only reveal the beauty of the prep work. That's a long way of saying the wax did nothing to restore the dull finish to the spot.
That's when I decided to use a fairly new weapon in my grime fighting arsenal, Pinnacle Paint Cleansing Lotion (PPCL). This product accomplished what I had hoped for. I treated an area about 6" in diameter with the spot in the middle. When I wiped off the PPCL I could no longer detect where the dull spot was. :up My hypothesis is that the bird bomb still had some residual layer of crud on the paint that was causing the dull finish.
I had expected the circle that the PPCL was applied to would look significantly different than the waxed area surrounding it but it did not. So I just rewaxed over the PPCL area with a overlapping strokes outside the 6" diameter and now it all blends perfectly like nothing ever happened.
<em class='bbc'>clic pic[/i]
http://store4.yimg.com/I/classic-motoring_1665_875885
Yeah, I have had the same experience. I use Meguiars Medallion paint cleaner with good results on those stubborn spots also.
Preventative wise, a polymer will greatly reduce the etching caused by acidic crap (literally ;))
But I usually use QD and make sure to wash it when I get home, some use a baking soda solution to netralize the mess. I QD of bugs and tar (but I don't get tar usually) Rewaxing is a must if you use anything that might strip off your wax (and that goes for wheels too).
Wow. Just wow. If word of that link gets out, there will be no more work for us to do. Everyone will be grinding away at their car and who will look stupid? Us, that's who. :rolleyes:
So I should apply the compound as if I am sanding the panel, and to completely eliminate it, "fill" it with Zaino. I've been doing it alllll wrong.
Shoot if its that simple I (we) are all out of a job. Lets all change our practices to follow this guy, he seems like a car care expert! Lets get this guy to be the head of PAC forum, sorry Todd you are going to be replaced we found someone with more knowledge than you.
:rofl:
Jon
