How to Remove ONR Coloring Stain from Polyester Quilt?
Nopstnz8
Member
Ok so for about three years i've been using ONR in a spray bottle at around clay lube strength to clean my MacBook and iPhone. It's worked great everytime, but today was different...
I went clean my MacBook on my bed quilt like always, but i guess while i was spraying it, the solution must have gotten sprayed on the quilt because now there are like 20 small blue die spots in an area on the quilt. I've sprayed ONR on it before unintentionally before and nothing happened, but maybe the bottle leaked too? Anyways, I know it's from the ONR because a few months ago i got that same dye on some MF's I use.
Does anyone know of a safe product to use in order to remove this dye from my quilt? I'm not so sure if APC would be too strong, ruining my quilt as well. The quilt is made of polyester, and I already tried scrubbing with dawn, as well as using rubbing alcohol, and while that did make it slightly lighter, the majority still remains.
Any help would be appreciated. Thanks.
Sorry no advice on the stain , burt I do have advice on the cleaning of you computer. Don't spray anything on the computer or laptop. I sprayed windex on the screen of my indoor pool controller and it shorted out the panel. I had to by a new $500 panel. ouch:tape2:
Can you either put it in the washing machine or dry clean it? I doubt the color stained it permanantly. I'd call Dr. G to get his opinion.
Agreed -- spray it on a MF and then wipe down what you're trying to clean.
Yeah I plan to apply something like spray and wash, then throw it in the wash. I hope it works. Thanks.
Yeah that's exactly what I do, but thanks for looking out.
