With both wheels off, start the car, throw it in gear and hit it with a rotary sander as the rotors turn. Suggest starting with about 120-150 grit, go as fine as you like for the polish.
Vincent231 said:Is there a way to do this without a rotary sander? I don't own one, so could I mount a sanding disc on some sort of stationary would block (or buy some sort of inexpensive housing with a handle on it), or is it essential that the sanding disc rotate as it makes contact with the brake's disc?
Vincent231 said:I tried applying CLR to the driver side disc brake on a 2000 civic hatch yesterday, but instead of getting a nice mirror shine I ended up with a white matt finish. By the next morning, it had turned green. Any thoughts on cleaning disc brakes?
Vincent231 said:OK, thanks. Gixxer, I'm not convinced clearing the corosion with the brake pads is really a concern -- as you may have read in the thread referenced by eecc, some people go so far as to bake high temperature paint right onto the brake discs while they colour their rotors; they let the brake pads scrape off the excess paint with no adverse affects, so I'm comfortable letting the pads brush off a bit of oxidation.
