How to remove caked Menzerna FP splatter??
sbkang
I think I've figured out what the magic Menzerna abrasives are made of: Kryptonite.
I had some Menzerna FP (original recipe) push through the roof seals on SLK hardtop and make some splatters on the center console. (Yes, I taped first. Apparently not well enough. Let that be a lesson....) I didn't catch it for some days, during which the car was in hot sun. How, now, to get it off?
I have tried alcohol and various other commonly available solvents/removers (goof off etc). No dice. Kryptonite, I tell you.
I use some all purpose cleaner (EFHI) and a small brush to scrub with, takes it right out.
I've removed DACP and Menzerna Intensive and Menzerna Power Gloss spatter on glass and plastic with Vinylex and a terry towel or a SOFT toothbrush in tight places and cracks. BE gebtle, as the stuff is still abrasive and you will end up with visible micromarring on the paint (but not on plastic or glass. I've had less success with a 50/50 mix of isopropyl alcohol and water.
