Todd@RUPES
Just a regular guy
Perhaps your car's interior has suffered the fate of by older Matrix. It has faithfully served its duty, getting myself (and by brother before me) from point A to Point B for nearly 10 years. In this time, the interior has been subjected to sunlight, temperature extremes, and general wear.
That dash and uppermost horizontal surfaces are beginning to show the results of constant UV exposure, age and neglect. Now is the time to rejuvenate & protect it.
The slightly faded and dried-out appearance of the Martix's sun beaten dashboard.
What You Need:
Clean First:
The first step in rejuvenating dried out interior pieces is to clean them well. You want to remove as much dirt, grime and soil as possible. BLACKFIRE Interior Cleaner is a gentle, water-based formula that uses advanced, free-wiping surfactants, not harsh chemicals to deep clean ANY interior surface.
Spray directly onto the microfiber towel.
Spread the cleaner "with passion" over the surface.
3
Flip the towel over, or switch to a fresh towel, and lightly buff dry.
You can use BLACKFIRE Interior Cleaner on any surface which is safe to be cleaned with water! This includes the steering wheel...
upholstery, metal trim, fabric, leather & more!
Rejuvenating with BLACKFIRE Interior Protectant:
Rejuvenating dried out interior pieces is different than protecting them. With interior pieces that are in "good health", the protectant will simply sit on top and coat the piece. On worn pieces, you may notice that product will tend to absorb into the piece.
Spread BLACKFIRE Interior Protectant over the faded and worn piece.
At first it will look like you have an even coat.
But the piece will appear to "drink" the protectant. Add more product to the bare spots.
Continue until you can achieve an even coat. In the case of the Matrix, it took 3 coats within a 5-minute time frame to achieve. Allow BLACKFIRE Interior Protectant to absorb for several minutes.
Wipe away excess product to achieve an even shine. BLACKFIRE Interior Protectant is a low-gloss, rich-looking protectant. Additional shine can be added, if desired, by applying additional coats once the first coat has cured.
The Results:
From the outside (do not mind the dirty glass!)
What You Need:
- BLACKFIRE Interior Cleaner
- BLACKFIRE Interior Protectant
- All Purpose Microfiber Towel
- Microfiber Applicator
Clean First:
- Spray BLACKFIRE Interior Cleaner directly onto an all purpose microfiber towel.
- Lightly scrub into the surface with the "wet side" of towel.
- Wipe clean while the surface is still wet to remove any soiling or dirt.
- Apply BLACKFIRE Interior Protectant directly to a microfiber product and spread over the trim piece, working a section at time.
- Continue to add more product as the piece "drinks" in the product.
- Repeat until an even coat is visible on the surface.
- Allow the even coat to penerate for several minutes.
- Wipe off excess with an all purpose microfiber towel or the backside of the applicator.
The Results:
