Anthony Orosco said:First, are you positive it is real aluminum and not a coated metal or plastic?
Anthony
Grimm said:If it is fragile then I question whether it's really anodized. The purpose of anodizing is to give a hard, more durable surface since aluminum is a softer metal. Anodizing actually is more than just a coating, but actually is made part of the surface of the metal. Even if you do somehow remove the anodized surface, you should be able to polish the bare aluminum..
Accumulator said:This is just an educated guess but I'm lean towards real aluminum. .
joyriiide1113 said:It is real.. Really soft aluminum may I add.
Accumulator said:So it's not anodized or anything like that?
