How to correct?
Cadfael
Member
Had this ‘stain’ (?) that obviously from windshield washer fluid since I got my car. Tried claying it soon after but with no joy. Suggestions?
attachment.php
It’s really going to be based on what the white staining is based on. It looks like a dried up etched water spotting. Chances are you need some form of water spot remover. But if it is etched down in to much you will most likely need to try and remove the nozzle and polish that out if you can.
Most of the washer fluids are very corrosive. Since I`ve switched over to Nextzett, I`ve eliminated that issue. They don`t use methanol.
If you can get rid of the white spots, I`d call that a success and leave it alone. The etching may be there to stay.
I use nexzett in our cars but who knows what they used before I bought it.
Bad news: definitely etched. Good news: reduced the appearance of it.
attachment.php
attachment.php
I hit it with Wolf’s medium cut on a ccs correcting orange hand pad then the medium cut on a Griots Orange correcting pad on my new G9 and then Mezerna SF4000 on Griot’s black pad.
Guessing adding a little touch up clear wouldn’t do anything good to it.
I did not know that windshield wash solutions could do this. I use a winter-based solution good for -25°F since I live in Wisconsin and keep that in the windshield wash liquid reservoir year-round. Makes me question the validity of doing so and maybe changing to a truly summer-only wash solution. I just hate the hassle of removing the reservoir and dumping out the seasonal-solution in the spring and fall all the time.
Cadfael:
Final results looks great from what it originally was in the posted pics. How do you like your G9 polisher? Looks like you know how to put it to good use!!
This was the first time out with the G9. It was a mixed bag. It was definitely more powerful than my old PC and the ergonomics were better. However, felt heavy and had more vibration. It also got hot to hold really quick. If it does that next time I use it I’ll call them.
Some washer fluids have a high percentage of butyl cello solve content, and if allowed to set and any warm temps will attack and eat the clear. First step is to remove the visable deposit and then check with a magnifier for cracking, if so, good luck.
Posted this on the other forum too. Pop out that washer nozzle from under the hood and that will allow you to work on the paint without it in the way.
I am quite afraid I’ll need to remove the stripes soon as they are quite tatty. I’ve been fighting doing it because they belong to the special package (Last of the Supercharged 100) but more because I know it’s going to be a big chore.
attachment.php
attachment.php
If you remove that stripe be prepared for the paint to be darker than the surrounding paint if the car has sat outside quite a bit.
I would be surprised if that weren`t the case. I`d expect it to be so severe that the stripes will need to be replaced for the car to look right. So, just FWIW...if it were mine, I`d leave `em alone and consider it "patina". Hey, it`s not (IMO) evidence of abuse or damage, it`s just...age-related wear/tear. The oe PPF on two of our Audis have cracked, and eh...OK..they`re not new cars any more.
what would be the best LSP/coating to put on them to wring out the longest I can get out of them?
Noting that I`m *NOT* dialed-in on all the modern products :o ...I`d use Optimum Car Wax. It protects against (further) UV damage and doesn`t "dry white" in the cracks. That`s what I`m using on the cracked PPF on my wife`s A8 and my `93.
