How to clean your character lines
waxinator
I havn't found a great tool or brush yet for cleaning caked wax and dirt from character lines and molding edges. When junk gets in these areas it seems to deminish the hard work we enthusiasts
are doing. I'm sure you will agree. Looking for something that's
aggresive enough to get in there but not enough to scratch
the finish.
I tried Q-Tips in the fall but they seem to be so-so.
Who's got the answer?
Wax
I'm not sure what you mean by character lines but I'm guessing that you don't mean shut lines or you could just open the hood,trunk or door and clean off the wax on the sides. I had a tricky spot on my car to ge the wax off of. On the fronts of the rear fenders there is a layer of vinyl designed to protect the paint. The line where the vinyl met the paint had caked wax in it that I couldn't remove with QD and a MFT. I ended up using a very soft bristled tooth brush with good results.
Yeah GMN.
A super softee toothie may do the trick.
I would slap some auto wash on it [like tooth paste] and brush the knooks and crannies as a pre-wash step.
Now were really getting down to the nitty gritty. Hu! LOL
I don't think I would want to sacrifice a good MF as
the grime and dirt would most likely be stuck there.
Thanks
I like using foam point tipped laquer brushes, the kind with the wooden handles to get into some nooks and crannies, not to mention application for my favorite interior stuff in the inside.
I like MF's too but aren't the loops[they don't have loops do they]
a little too small to trap dirt.
In other words if you have large particles trap in your MF it
can turn your MF into sandpaper vs. a nice Fieldcrest or
a cotton chenelle washmitt where the particles can rise up
into them and not harm your paintwork. Just my 2 Cnts.
Yes use a nice soft brush (china bristles for instance). i wouldn't put car wash on the brush though. If you need to, use some QD, but definately not car wash.
GMN, I have not seen the bigger MF's yet. I have only the
tile size ones from Zymol, so in my ignorance the larger
towels probably have larger naps. For washing I use Fieldcrest's
for the top 90% and Detailer's Choice Cotton Chenille wash
mitts for the lower 10%.
And Brad, you make sense with the QD Vs. the Wash syrup
on the brush.
Thanks
Wax
I've had good results using an expensive, non-synthetic paint brush in $10 range. 1 1/2 to 2" size works best. Get one with feathered tips and put duct tape over metal band that hold bristles so it won't scratch the paint--I learned this the hard way. If you find the brush too soft, you can tape the first inch or so of the bristles above the metal band to stiffen the end of the brush. I've found this set-up will remove all but the most hardened wax/polishes and it will not scratch. I use the brush after every application so it doesn't build up. You can brush every crevice in a few minutes. If something is petrified, I use Pinnacle cleaner or Stoners Xenit or denatured alcohol to remove it.
