How to clean carpeting?
volfan
I need my entire carpeting cleaned. But how do i do it by myself? The only cleaner for carpeting I have laying around is called "Blue Magic", anyone heard of this? Do I just spray it on, and scrub? Or do I use dish soap and water? Do I need a special vacuum to remove it? The nearest detail shop wants like $70 to do this. Any tips on how to do by myself would be great.
The carpet in your car is like any other carpet. You can use a foaming type cleaner and work it in or you can use an extractor type like the Bissell type machines. The only trick I have found is to use a brush to raise the nap. There is a lot of information in the ebook, even in the free section, if I recall correctly.
go to walmart and get some resolve granuals...comes with a brush for about $3.00...shake, sprinkle, brush, let dry, vacuum..........works amazingly well:xyxthumbs
I've been looking at the Bissell's but was curious how often can you use these? Do they have negative effects as well and should only be used like once a year?
