highspeeddata
My brand new Acura bumper now has 3 chips (about 1/8" wide by .5" long) down to the black plastic and a 6" by 6" area where the bumper rubbed that has a bunch of straight hairline scratched that I can barely feel with my finger nail. I've tried Meguiars #2 Fine Cut cleaner (by hand) and it doesn't take the scratches out.
I'm planning on touching up the chips, leveling with 1500 grit wet sanding, compounding the chips and scratches with 3-M Perfect-It II, then polishing with 3M Swirl Remover for Dark cars. (wish me luck).
My question is related to this particular situation but also making future repairs to the paint finish as necessary.
I have been reading all the information on this site and I am a bit confused about the necessity for using a power buffer, orbital or otherwise. The prime example of repairing a scratch shown on this site (with the black Porsche) was done totally by hand and the author also advocates hand polishing over using a machine. The main reason for a machine (which pros use) is that it takes much less time. However I thought I read that only a buffer can heat the clear coat up enough to effectively repair this kind of stuff and that the random orbital buffers will not do this, only direct drive, which is not safe to use by an amateur.
1st Q) Is there any big advantage to using the Porter Cable Ultimate Detail Machine in trying to repair just a small area or is hand compounding and polishing going to be just as effective with a little elbow grease?
Since I have a dark car, I imagine once a year I polish out the swirl marks and spider webs. I'm assuming 3M SMR for dark cars would be the best choice. I use Klasse Sealant Glaze to finish. It would be nice to save some time using a machine, but at only once a year, maybe the workout by hand would be good for me?
2nd Q) I have one of those big 10" random orbital polishers (the onces that just kind of jiggle around and don't spin fast like the Porter Cable) they sell in Schucks. Would one of those effecitively apply SMR and Klasse SG (with a foam bonnet) assuming there are just very light swirl marks and spider webs? Or, should I stick to hand application (with back and forth motion) or a PC Detail Machine? The PC really only seems beneficial to people that detail A LOT.
3rd Q) I think I've read in some posts that certain polishes are not "compatible" with the Klasse polymers and make it difficult for them to bond. Is 3-M SMR one of those? If so, what is an alernative for removing swirls before applying Klasse?
Thanks
Thanks
