How much product on the pad
I was wondering how much product do you guys place on the pad. I was reading that some people use a couple dime size drops, some make and "X" and if I understand the KBM is a whole other subject. Does the amount matter if you are using a compound or a polish, a DA or a rotary? I am always second guessing myself if I am using too much product or not enough. I know that should be about 1-2 oz for a normal vechile. Maybe some pics if you have them.
Thanks
I use the "X" method. (Unless I'm using Zaino, then it's a "Z".... haha!):smile:
I also "prime" the pad, meaning that I lightly spray the pad with one spritz of water or detail spray, then rub it into the pad with my finger until it is completely absorbed into the pad....:thumbup:
Thanks
Pea size drops for a PC (3-4) and a 6" Bead for a Rotary.
Place a small amount (approx 3 x 1/16th-inch diameter or a 3-inch X) of polish onto the centre of a clean primed pad
