How much ONR solution do you use?
mikebai1990
I'm wondering how much total ONR solution (not dilution) to mix up when cleaning up a moderately dirty vehicle. I understand Scottwax only uses 1 gallon, and I'm wondering whether I would be able to do the same. It seems to me that maybe 1 gallon might not be enough to wash a midsize sedan? Since I haven't used ONR yet, I obviously can't be sure though, so I'd like to hear how much ONR solution you guys use :)
1 gallon will definitely not be enough depending on how you use it, im sure scotts tutorials should help you, make sure youre not pulling a heck of a lot of solution out with your mit, wring it out a bit before washing and one gallon will go pretty far.
I usually mix 1 and 1/2 gallons for a sedan, and 2 gallons for an SUV. Usually there is at least a half a gallon left over. Note, I usually do not use ONR for wheels and tires etc.
