How many times can you 'PC' your car?
YNOT
Poorboys Rules!
I'm just curious...how many times can one 'PC' their car before finally going through all of your factory clear?
I know it removes a very, very slight amount of clear each time you buff...but how many times can you do it before you go all the way through?
:thanks
not sure how many times but i normally use the rotary.. and i've wet sanded my hood.... speaking of i do need to polish her out again...
I guess it really all depends on what type of polish and pad you use. If you use SSR3 and a high cut pad on 6 every time, you'll go through the clear faster than someone who only uses a finishing polish and a finishing pad.
It would depend a great deal on the product and the pad.
With the products most of us use, I would guess the PC will wear out before your clearcoat does. :)
Stick with polishing pads and milder polishes and I think you can go for years. Our 2000 GTP has had the PC used on it since 2002 when I first got the PC.
I actually only really polish to remove swirls a couple of times a year and then only in the areas that need it. An AIO type of product about every 3 or 4 months and a wax/sealant by hand every 4 to 6 weeks.
Charles
This is a good question!
With a PC I don't think that it would be possible to burn or go threw the clear..I'm not saying its not possible...the thickness of the clear, pad, speed and product...would have a bearing on this,...but for the average person..using it on their car, even once a month.. I couldn't see this happening...you would have to be pretty aggressive to make that happen
that's my opinion
With a rotary that's a whole different thing...but that's not what you asked
I agree with most of what has been said:rockon
It is almost impossible to go through "factory" clear with a PC, a repaint would be another story. I have heard of people going through repainted finishes with a PC because of poor workmanship and not enough clear. :)
It would take a very long time, but if the pad and product were aggressive enough, I imagine it could be done.
I do not use a paint gauge so I don't know for sure, but I've always thought and have been told by painters that repaints usually have quite a bit more base and clear than the factory puts on.:hmmm:
When I worked as a paint and body tech, yes, we put on more base than clear. Unless the customer requested additional coats. One guy wanted 10 coats
Yes, more base as the repair shop does not have the robotics to spray as even and thin a coat, but as Chris said below, it will only get as much clear as a customer will pay for. It usually will not dry as hard as a factory paint either, and need more outgassing time.
