How Many Dilution of Exterior/Interior cleaners do you have on deck : Dare I even ask a fellow Autopian
mobiledynamics
I feel like i`m on the axis of overkill but I have 4 bottles of the same APC cut 4 different ways.
Sometimes, I`ll cut it even more by just spritzing on what I need and then a quick spritz with the water bottle..
More often that not, I`m striving for minimalism/simplicity but I swear, this is never going to happen....I always tend to add more to the *go to stash* than shelving it all so it`s less visible. Yeah, I know most of you are probably the opposite and like to see 50 products on the shelf. Ha, if it was me, it would be 9 bottles max *2 shampoos, a light interior cleaner, 3 APCs, a premixed WW and glass*. Everything else would be out of sight.
Was on USP ordering some more plastic jugs today to rebottle my larger stashes.
Had a little incident where I shoved a product into a corner ---in which it created a sharp crease, that got pushed into that same corner even more---and leaked product out over a slow drip.
For my APC...two.. Heavy and Lite
Seems most of us are crazies with too many products and what nots. I`m "trying" to thin things down a bit.
D108 Super Degreaser (4:1)
I use this to clean neglected plastic and rubber trim, wheels, clean water-based dressings off tires, moderately dirty engine bays. I also use this dilution to clean heavily soiled interiors because even at 4:1, D108 has proven to be safe on vinyl and leather without leaving a residue, although as a rule I still always go back over interior surfaces with a cloth dampened with D156 or D114 to neutralize the alkalinity of the degreaser.
Mckee`s 37 APC+ (10:1)
This is my primary cleaner for cleaning moderately dirty interiors. I use it on leather, vinyl, plastic, and carpet. I used to use d101 on interiors but Mckee`s 37 APC+ works a bit better at removing body oils from leather and vinyl and is safe to use on clear plastic instrument panels where d101 isn`t.
3d Orange Degreaser (4:1)
This degreaser is what I use to clean tires when I need to remove silicone based dressings, it works well for spot treating carpet and cleaning heavily soiled floor mats, and I often use it for cleaning heavily contaminated wheel barrels. It`s also great for degreasing neglected engine bays.
....While Optimum Power Clean is still the most effective apc/degreaser I`ve ever used, 3d orange degreaser is the best value driven degreaser I`ve found for removing the grease on tires that is caused by using a silicone based dressings for years without removal prior to reapplication.
Einzett 1z Blitz (30:1)
This my be my most used product next to D114. I used it for all of my interior/exterior cleaning needs (other than wheels and tires) for all of my maintenance clients. It is EXTREMELY mild and safe and leaves no residue. I used it to clean the tile and hardwood floors in my house, I use it to presoak my microfiber towels, and clean 99% of my foam, microfiber, and wool pads with it. It does not have an skin allergies and it smells incredible.
