So I had some acid rain "stains" in my passenger side windows and front and back windshields. Tried everything I could(including a couple scratches courtesy of spotX!!).
Brought it to two detail shops and both failed at removing it. Finally decided I was just going to have them replaced via my insurance. So I made one last ditch effort with the assumption that I was likely going to ruin the window!
I was using some Mothers Aluminum Polish on the trim and it worked great to remove the acid rain stains. So I figured why not try it on the window.
I first tested a small area to see how it works; Worked great! I grabbed my buffer and used a soft pad applying the Mothers polish throughout the window.
All spots are removed and the glass looks great! No scratches,residue or any after effect of any kind. Hope this helps some of you suffering from the same problem.
:woot2:
:woot2:
