How does Paul use such a fast arm speed and get killer results?
The Rupes really cuts IME. I can use their ultra fine polish / pad combo to remove actual defects on my BMW. I have not been able to remove defects with other ultra fine polishes and soft pads with other machines.
That is why I like it. Because it just works.
It's virtually impossible to dry out Rupes polishes. The have very long buffing cycles, the pad stays damp, and it doesn't all clump up in the middle of the pad.
Must be - 'cause in the video he's polishing an entire door for 2+ minutes !
He's barely using any pressure to keep the pad on the door. Just before that part of the clip, the title cars says the correction was completed so I think he's applying G-Techniq or wax.
No, i've seen many of his videos. He doesn't seem to have take it nice and slow much, alhtough there are some instances, most of the time its usually pretty fast compared to the industry pros.
He does what works for him. Simple. He perfected his technique that way.
Might not work for you, then again, it might.
Me, I perfected the fat and lazy technique
