How do you use spray detailer???
technomafia
after you wash your car do you dry it first then go back over it with the spray detailer??? Or as its wet you spray it on and wipe the water and detailer off at once???
dry and do it. Wipe on wipe off.
Coupe, hi from another GR Resident :wavey. NOTE - 5 more posts as of now until you're 1337.
I used to spray it on while wet then wipe dry with a chamois. after that I would buff with a MF cloth. that worked great.
If its a spray wax like AW, you can spray it on while the car is still wet and then dry off. If it is not, then dry the car and then spray and wipe off.
