I use a foam applicator and use a front to back motion rather than a circular or side to side motion. I usually let it sit for 15 to 20 minutes after I'm done and remove with a couple of microfiber buffing towels. Natty's goes on & off easier than any thing else I've used.
I would agree with the ease of use. I just finished applying Natty's blue to my wife Sentra. I apply the wax to the entire car using a Megs foam applicator. Then, I begin wiping where I started with a PakShak Ultra Plush. It came off easier than it was applied. I would guess the wax was left on the car fro about 15 min.
I have used a yellow foam applicator dry, I have used one damp, I have used pva's damp ....spread it out thin, either half or whole car, wait for a haze...and then wipe off...
I have started applying all carnaubas with a damp applicator and also use the spit shine method. I think the results are superior and I use far less product.
I'm partial to the Wolfgang Polishing Pal for an applicator and use front to back (in the direction of airflow) for every thing I put on a finish. I put the first two layers on with a spit shine technique and do follow-up layers with Natty's dried to a haze and removed with a light spritz of S&G, using a plush MF for all removals. The spit shine technique, with refrigerated distilled water lets me get two coats of Natty's on at one go after a full detail and the Natty's/S&G for follow-up is as quick and easy as anyone could ask for. The removal with S&G was a tip from another member whose name I simply can't remember. I think it adds a little more zing to the finish and it certailnly speeds up removal by making any dust come up to the MF and stay there much more quickly.
I mist a cotton/foam applicator with water or S&W till it is thoroughly moist, then apply Nattys in a 'front to back' (front bumper towards rear bumper). I do the hood, roof and trunk, then wipe it off. I then do the drivers side, wipe off, the pass side, then wipe it off.
