How do i achieve a flawless finish?
Spaceman
After correction work and polishing with a rotary i still have a few spider webs in the finish. How do i achieve a spiderweb free finish?
This almost sounds like asking for directions to Carnegie Hall. Are you sure you are not putting the spider swirls back in with your polish/LSP removal or with your maintenance practices?
Well, then the answer is going to be very involved. What kind of paint, what's your products and processes, etc. There's all kinds of technique, product, lighiting issues, etc.
+1,000,000
I've been using the rotary with the m105 and a light cut foam pad, then i use the m80 with a foam finishing pad on the orbital, then i apply a paint sealant m21 or m20 with the orbital.
If you still have paint defects, your not done with the correction.
