I want to add some more coats of Z5 before the winter, but the weather has shifted to cold real fast. When is it too cold for Z5 to work properly with the Flash Cure?
In their old instructions they had a minimum temperature. Can't remember what it was off the top of my bean, though. It seemed like it was around 50 degrees if you weren't using ZFX, and there wasn't a min temp for application with ZFX.
If you have a halogen light stand you can always use those to warm the surface long enough for it to cure.
