Hot water extractor?????
andrew43
Hi all,
My BMW 330i has approximately 3500 miles on it now, and in the right light, I can see swirls in the wood trim that surrounds the shifter (on the center console). I was wondering what product would be safe to remove these swirls and get the wood "shining" like it does on my dash and doors.
TIA!
I may be wrong, but chances are the trim has some kind of a clear coat surface on it and you should be able to use a mild swirl mark remover just as you would on clear coat paint surface.
They put plastic simulated wood in BMW's? I was thinking it would be the real thing. Wouldn't a mild paint abrasive be effective on the plastic surface too?
The BMW has real wood but like just about every other wood trim out there, it has a thick acrylic coat on it. Thanks for the suggestions guys..I'll try it out!
After the scratches are removed using a MILD abrasive, as DETAILKING pointed out, protect the plastic with a plastic protectant. I would recommend Plexus to protect and clean (not remove scratches) the plastic.
Im thinking about getting a hot water extractor for my detailing business. I have never used one but the internet says its the best... i was wondering if any of youall have used one and is it worth the money verses my hand, brush, and wetdry vac?
Peace
Jon
I only detail my own car and a few others only here and there so I only use Bissel's Little Green Machine. By no means is it as good as an extractor but for the hobbyist, it does a pretty good job. If I were doing detailing full time or maybe even if I were cleaning mats, carpet and upholstery every weekend I would probably put up the money for an extractor. If I were in a fixed location I would go for the Mytee 8070 or the HP60. If I were mobile, I would probably go for something smaller.
I have a Mytee HP601; its not small, but it pulls the heck out of the hot water/solution it injects at 100psi into the carpet. It will totally clean any type of upholstery, carpet, etc., even the pedals while you are down there cleaning the carpet. But the drawback, its big, but has nice wheels, you would need a van or truck, jeep, something with a big space, to haul it around, and it requires a 20amp circuit they say, but I seem to be ok running it at 15-20 amps, depending on what circuit I use in my garage.
You would be amazed at how dirty the return tank is after you do even floor mats that look clean and have been cleaned religiously- there is still a ton of dirt down there at the bottom, that this unit will pull out. It will have a tougher time with lots of sand, because sand tends to let water run past it, and is harder to extract at the very bottom of carpets, etc..
I feel for me, it is a necessary tool today given how much dirt and crap we already inhale in some housing that was built with leak problems that introduce dirt, mold, etc., the stuff that causes sick building syndrome, etc., so I will always use it in my vehicles and everyone that comes through my garage.
These boys are not cheap, prepare to spend almost a couple of grand for one as big as mine, and less for smaller versions. I chose Mytee for the reputation and the ability to change out the various pumps and motors easily if/when needed.
ProperAutoCare sells these, and perhaps other brands.. And of course the Internet has hundreds of models, trust me, I know, because I ran all of them down, before I made my purchase earlier this year..
Good luck with this !
Dan F
Does anyone else have a LGM? How well does it work? I have seen reman ones fairly cheap.
I just used my Mytee HP601 to clean some really clean gray carpets out of a Cobalt Ski Boat this afternoon.
After vacuuming with my MetroVac VNB-73 and then spraying a professional cleaner on the carpets and extracting with 187 degree water, I still managed to pull out about 3 gallons of dark brown water out of these very low tight pile gray capets!
They didnt look dirty or brown, they looked fine before and after vacuuming, but I still managed to get alot the dirt that sits at the bottom of the pile out.
I still vote Yes for extractors, and if you get a bigger one, you can also use it inside to do your own carpeting with a standard long, 2-jet wand and start saving money on calling the Stanley Steemer, etc., guys out..
I believe the water lift on mine is 135" of lift, so that is pretty darn good.
Believe the really big units give you like 200" of lift, so that means they make fewer passes while mine may take a few more to get almost all the water, soap residue, dirt, etc., out.
They even make extractors and tools to clean grout, tile, all kinds of stuff..
Dan F
Hot Water Extractor--Purchase
I'm looking to purchase an auto detailing hot water extractor for my son-in-law for xmas---anyone have any suggestions? I've been looking at the mytee lite 2 8070, duramaid 1600 and Aztec. They all fall in the 600-800 price range (top of my range is $1000 max) and I'm just not sure which features are more important. PSI, heating time, tank capacity? I have no clue so any help would be appreciated.
I've used my Mytee Lite II 8070 for about 2 years now and absolutely love it. The only thing I've learned to do is fill the clean water tank with super hot water from the wash room first. That helps the heat time up faster (about 10 minutes vs. 20 minutes). Also, I've never filled the dirty tank up even after a full sized SUV so the capacities are right for me. If he's only doing one vehicle at a time this machine has worked very well in my experience.
My only regret is not having the crevice tool. If adding that stays within your budget I would suggest that.
