High Iron in Water...Reccomendations
EOppie
Hey Guys,
I have recently moved to a location that has high iron and hard water. This results in spotting on areas of the car that I can not immediately dry, however they come out with some QD, just a pain to remove.
Is ONR a good solution for this problem? I currently use megs GC wash.
Yes ONR will solve the problem
because you wash then dry one section at a time
give it a try I think you will like it
EOppie- Car washing aside, you might want to install some filters and a water softener. We have pretty crappy water at our house, and adding some inline filters and softeners helped a lot. It's pretty shocking to see what gets caught by the filters! We're running two 5-micron filters, then the softener (two identical systems, one for house one for garage). And even with all that we use a RO unit for our drinking water.
Unfortunately we have a bit more problem than that!
We have a 2 stage micron filter setup, water softener, as well as water purification system...
Still crappy!
No kidding?! That's not good. I just got a 2-stage filter/softener in hoping to help solve a similar problem here. Was going to try it out the next day or two. Hope I have better luck!
our water is pretty bad- I find that NXT wash works well for hard water. Duragloss Water Spot Remover also works great at removing hard water spots without removing your paint sealant.
