Here's something new to try...
Poorboy
Founder Poorboy's World
i was experimenting myself on my 67 Caddy and found that using my QD+ first and then spraying some Spray and Wipe over it and then wiping off with a microfiber towel, cleaned , shined and gave one of the slickest surfaces I've ever felt with no effort or time..
Just a thought and both products can be gotten here at premiumautocare....
I wonder if I use some............
I just place'd an order...and that was one of my items...(Spray and Wipe )
This is a 2 step process...using a Qd then your spray and wipe??
jeff
No Jeff ..just one step for removal...first sprayed the QD+ on the dirty surface, used a piece of card board to avoid it getting anywhere I did't want it to like glass and tires....then sprayed Spray and Wipe over it and wiped it all off..did a light buff with a clean mf and it was really so slick I couldn't put a bottle down on my somewhat flat hood of the 67 Caddy..
spray and wipe is a waterless wash made by poorboys. It's at the on-line stroe under porrboys.
Oh...thks....I .Should get my order...maybe on Monday...Will try it..can;'t wait!!!
jeff
Poorboy,
Let's see if I have this straight............. you sprayed (didn't wipe it around) the QD+ over the entire vehilce (letting it sit). Then came back and sprayed the S & W over a small section and wiped it off?
Thanks
Ok so your saying you s&w isn't good enough? We need to use two of your products to do the job of one? Hmmmmm something fishy here. Sounds like a sales gimmic. ;) j/k I just might give it a try. You have to admit though it does sound like a marketying ploy. Two products for one purpose? Why not just sell it premixed?
Koop ..everyone here is always EXperimenting and I do also...
I was looking for an easy, time saving, way to get the best of both worlds, waterless washing and waxing in one shot....
I also do this for the mobile detailer in me, who is always looking to save time and work in the sun.
:cool:
Edit: just saw your last line...will work on it...;)
I wasn't doggin on ya poorboy. Just saying it really sounded like a gimic. Notice i even said i'd give it a try. If it works then that's just great.
