Help with SMR for my next order
2drtahoez71
I have basically everything I want, but im lost as far as SMRs go...there are so many.
I have my eye on Megs DACP. Would DACP followed by PB SSR1 with a PC take care of most swirls I would encoutner on customers cars, or will I need something more aggressive...like Meguiars No. 82 Swirl Free Polish? Or what about the 3M Perfect It III series? (Keep in mind I dont have a rotary, so everything has to be PC friendly)
I have heard good things about DACP but have not used it...but The entire Poorboys SSR line is awesome a bottle each of 3 -2 and 1 should arm you for any job. (most of them can be accomplished with 2 and 1 - 3 for the harder ones).
DACP is more agressive than swirl free polish ( by 50%). Without seeing the swirls you are going to encounter it is hard to say. Since you want to use the least agressive product for each car to do the job, I think I would get a couple of swirl removers.
I persoanlly would have DACP, Speed glaze, and SFP. I would also have SSR1 and SSR2 for those times when I work in the sun.
FWIW, I use speed glaze most of the time. It takes care of most the swirls that I see.
I would go for one with fillers and one without. Poorboys products are superb and probably the easiest to use. Humidity? You can practically use the products in the rain. I like the 3M SWR for dark colors when I have to do a bit of filling like on black or red. You don't want to take off too much paint, so it's wise to use something with filler when you need it.
I searched through the hundreds of photos I have for my DACP followed by SSR1, and don't have any close up before and afters, but I can assure you, DACP has been a powerful tool to my arsenal!
P.S. I've only had DACP since December 1, 2003, so I've only done a few cars with it.....sorry
The Poorboy SSR's do any job I've encountered and they've done it well, even in the sun. I don't use any of the others any more. Why confuse things? SSR 1, 2, or 3 followed by polish with or without carnuba and then a couple coats of EX and detailing nirvana has been achieved. :)
the order of aggressivness (from highest to lowest) goes:
SSR3
DACP
SSR2
SSR1
correct? (i know 3 is higher than 2 and 1...im just making sure i know how aggressive DACP is)
