Help with Polish & Pads
jw
I've been using Menzerna IP & FP(the old kind) for the last few years with my PC. For pads i've been using LC white and yellow also from a few years ago. I've never really been blown away by the results. It never really seems to get rid of all the swirls, I do admit that i've had problems using IP. Do you think I should buy some new polishes(maybe Menzerna PO106FF), or should I maybe get some new pads. If so which ones? Any other helpful hints?
Thanks
You might be at the limit of your PC.
Pads-I guess you are using the IP with the yellow and the FPII with the white? You can use the newer polishes like 106ff and SIP with a PC, but your best results are going to be with a rotary. Have you thought about stepping up?
Not being critical, but maybe its your process. Maybe if you tell us your process, some fine-tuning may be suggested.
