I have an 07 BMW 335 coupe, white in color. Today while washing, I noticed two spots on the right rocker moulding. I decided after washing I would tackle them with a clay bar.
After claying for 10 minutes, the spots where still there. Fine, I need some cutting power I thought, so I took out the 3m Perfect It III, 5 minutes of hand buffing, and the spots where still there. So I stepped it up one notch, Meguiars fine cut cleaner. Still nothing.
The two spots are small about 1 mm each, and orange in color. They actually look like they might be under the paint. It has the color of normal metal corrosion, which I can normally remove with clay bar, but these two are not budging.
Any ideas or suggestions, I will post pictures up here shortly.
