Woob
Well its time to detail! no school + moderate cool = fun in the sun (hopefully)
Here is my order:
1) Wash - Rinse with free water flowing from hose (how do you stop the flow? i usually jam my spray head on)
2 bucket method. 1 bucket with hot water + dawn to rinse sponge occasionally. 1 bucket with 3 caps of mothers shampoo with bucket 1/2 full
Rinse down then spray on wheel wells + wheels.
Use purple power rim cleaner / APC + dilute ratio on tires / wheelwells
Dry with WW that have been washed through with tide + air dry
2) Prep - Inspect finish to see any dirt spots / object
TRY and clay with Meguiars bar (ridiculously hard might work) try and make sure the bar grabs the surface and causes some noise
Wash with UPP Auto Wash
Pro Polish - SSR1 or 2 if needed depending on swirls / scratches
(Use different applicator for each product, but u use 1 - 3 drops / panel or 2 - 3 foot area? keep rubbing in until the polish is gone?)
3) Finish - EX - apply 2-4 drops per panel in which u see a layer . remove right after panel is done?
S100 - I've never used a paste. How much do u apply? dap a little and apply like a liquid? usual 3-5 drops / panel?
What about QD? I got QD + S&W FD. ack so much stuff... UGE!
Basically I need simple info about application... thanks if anyone can input their knowledge... lets not waste my UPP / PB / Meguiars/mother stuff!
How much of each solution should i use? how is haze a factor?
how long do i leave each solution on? ack
please help!:shocked
Here is my order:
