help cleaning burnout rubber out of wheel wells!
The Enforcer
today i detailed a GTO that has been at the dragstrip alot. the rear wheel wells were CAKED in rubber, prob 1/4 inch thick on the back of the wells. what methods are people using to easily get this rubber off?
i sprayed the wheel wells down with a heavy duty APC diluted 5:1 (this stuff is recommened 10:1 for heavy things, i went even heavier). it took me about 20 minutes on each wheel well to get it clean, and then it wasnt even perfect, just about 95% of the rubber was gone. i used a regular fender brush to scrub it down, but found that my hand (rubber glove) worked better at rubbing the rubber off than the brush did.
Im guessing you're gonna need mechnaical agitation rather than simple chemical removal, try a strong car wash mix to provide lubricatin then got nuts with a bug scrubber. 400* rubber flung onto a plastic part is gonna be pretty persistant.
well....i mixed up some heavy duty APC twice as strong as they suggested for "heavy cleaning"......and scrubbed with a stiff fender brush....didnt work very well. i knew i would need to manually remove it, instead of rinse on/rinse off type thing. i wouldve tried a big scrubber, but i would want the rubber to get in the netting and ruin it!
I go to the track very often and the best method is cold water and your bare hands to start.
Once you get all the loose stuff off I use Stoener Tarminator.
To prevent this from reoccuring once the wheel wells are clean and dry spray 2 coats of Geddex Burnout Guard.
