Hello.. quick question about detailing environment ...
zhan
Hi... I'm new here ^^
I just traded in my 350Z for a 330xi.. but its been sitting at the dealer for a while so... its pretty dirty but today its like 40 degrees outside... I wonder if its ok to start detailing...
Wash, dry, clay, wax with NXT paste wax?
good question.......... as far as washing no problem. I think some of the directions on some of the waxes say the minimum temp range....somewhere around 50-60 degrees. As far as claying goes, I guess as long as the lubricant you are using doesn't freeze you should be ok. Welcome! And if you do a search with "temperature" in the subject, you'll get a lot more views on the subject. I just did and got over 20 posts. Very interesting stuff.
You "should" be good with a couple of adjustments due to the temperature. Some clays get really difficult to knead and form in cold temps - Wet it and warm it up in your hand frequently. Also, some waxes/sealants will take an extended amount of time to haze and set up during the cold - just wait a little longer than what the instructions say before removal or do the "swipe" test every now and then.
Hope that helps...MCA
BTW... :welcome to Autopia!
i dont know what you guys think of the NXT Paste wax but i personally think its really good ^^
