heavy oxidation
Vettecor
I just purchased a 1991 Ford T-Bird which is blue. All of the top surfaces have heavy white oxidation, but no cracking.
Would the blue paint still be good under the oxidation? What products would I need to use to remove the oxidation?
The only product I have is Klasse AIO. Also just have a 6" inexpensive buffer from Sears.
Thanks
Larry
PS- I think I posted on the wrong forum earlier. Sorry
Hey Larry, to properly polish this out you will probably need to perform a 3 stage polish starting with a wool pad, a medium cut foam pad, and a finishing foam pad. I would recommend the Menzerna line of polishes from Power Gloss to Super Intensive Polish to Super Finish, a set of Lake Country pads, white wool, orange foam, and white foam. You will also need to step up your machine to something with a bit more power. Unfortunately it's not too cheap to get started, but with some practice you can get a lot of use out of having the right tools. Otherwise, you could take it to a professional detailer.
John
In cases of heavy oxidization I have actually had great results with Meguiars ColorX ... you'll need lots of towels and a few applicators because it takes off the oxidization and pluggs them up.
It has to go somewhere ..
