Gjkwpd
Quick question in regards to water staining on headliner. What's the best way to remove it without making more of a water stain?
This is on my daily driver. I bought used and had a small spot. Attempted to spot clean it and didn't work.How much are you charging ?
I tried filed as well and it didn't work. That was why I ended up trying a foam cleaner. The water mark is still there. Will try to steam itI just worked on a F150 that leaked water in the third brake light. So it had water marks on the headliner. I sprayed Folex directly on the headliner, waited a minute, then wiped with a microfiber with medium pressure. I can check tomorrow and see if that eliminated the mark.
