imported_admin
Administrator
I have received the same basic question about HD UNO several dozen times now, so it's time for me to put it in a post and explain it. The question is this:
How can one polish do the job of a full range of abrasives from compound to finishing polish? It's not possible! You must be using fillers.
Okay, first let me roll up my sleeves so you ca see there's nothing up there. Honest! Everything I am about to say is 100% true.
HD UNO, like the rest of the HD line, was created from scratch. Brand new formula. UNO is not the top of the old game; it's the beginning of a new one.
The concept for HD UNO actually came from perfecting HD FREE Waterless Car Wash Lotion. I know that sounds odd, but it's true. HD FREE does its job of preventing scratching by creating a "suspension" between the paint surface and dirt particles.
Getting the hint yet?
HD UNO is a water based emulsion that's based on a brand new lubrication system. Thus, when you vary the polishing tool -- the pad -- you get more or less aggression.
HD UNO works properly with low-profile polishing pads... wool, foam or microfiber. The ideal foam pad thickness is .75" to 1". Thicker pads do not work well. Small diameter, low profile wool pads are also ideal. Traditional large, thick wool pads will not work.
The best way to understand the cutting capability of HD UNO is to compare it to Meguiar's most recent generation of polishes. HD UNO has all the capabilities of M95, M105 and M205, only it's a single liquid.
I have been called to task on UNO's "claimed abilities" on more than one phone call, so let me explain the rest. Lubrication is only half the story.
The second secret to HD UNO's performance is the size and hardness of the abrasive. On the Rockwell scale, UNO's abrasive would be considered a glass polishing abrasive (hence the reason I say... "Use it on your windows!"). This is why HD UNO can "cut it" on everything from fresh paint to a rock hard ceramic finish.
In the coming weeks, I will release a thread with my test results on pads that can be used with HD UNO.
:dance
HD UNO
:dance
HD UNO
