HD Speed with HD Nitro Seal After
Paul2011
So I used HD Speed on my entire car and it looks amazing! I was wondering if i could follow up with applying HD Nitro Seal or should i clear the wax/sealant component before applying it.
I would make Nitroseal the foundation before building. Once all polishing is complete, clean the surface very well so Part A has something to Stick to. Then apply Part B as the two bond together you have a terrific finish that holds up. I would not apply Speed Second because it does contain abrasives it will remove the NotroSeal. If you Like to layer I would suggest going, Nitro Seal then Poxy. THis combination is probally the glossiest I have ever seen. Recently I got a little over board and Applied NitroSeal, Poxy then 3d's Blue paste wax. Talk about a deep pool of Gloss. Oh man it sent shimmers threw my fat body! 3D's paste wax is a product that isn't talked about much, but looks spectacular on a car.
Whats the best way to strip a HD speed off the car i herd dawn works, CG Citric wash works, but is there a faster way?
That must have looked awesome! You don't have any pictures by any chance of it do you?
Did you know that the 3D Paste Wax contains 35% carnauba?
