HD Speed - All-In-One Polish/Sealant
Thomas Dekany
HD SPEED
Here is the easiest product I have ever used. It wipes off even easier than most waxes or sealants. HD SPEED is designed for light paint correction, polishing and protection. It will give the paint an amazing gloss, this is the closest you will come to HD NITRO SEAL.
HD SPEED is a combination of HD POLISH and HD POXY.
So while in LA, we wanted to see how much HD SPEED could really cut. Some people may not have an array of polishes and in case you want to really correct and SPEED is the only thing you have. These few pictures should tell the story.
* It is of course recommended that you use a dedicated polish or compound for medium or heavy correction. The car we used had pretty hard paint and the imperfections were fairly deep.
PCXP HD yellow cutting pad, 2 or 3 passes, followed by HD black pad
FLEX 3401 same process
Nice reflection
*Quick Light Paint Correction and Protection
HD[SUP]®[/SUP] Speed[SUP]â„¢[/SUP] polishes and protects the painted surface in one easy and simple step. Removes light to moderate surface scratches and swirl marks. This remarkable product restores color, depth, and gloss while adding a long lasting wax to the surface.
Great for those who want quick paint correction with amazing paint protection.
I have tried both ways, but since I am old and old school, I found that using a rotary at low speed and decent foam pad or lambs wool makes it work much faster with the same basic results.
Use of a rotary around the new kids on the block is heresy, but that's their problem, not mine.
I then take the DA and apply a light coat of the Speed to clean up any issues and leave some protection,.
I have found that the new Polish, with a lambs wool or good foam, is great.
Then I apply a sealant with a DA.
Grumpy
I love using uno with my rotary and a cutting pad followed by speed and a polishing pad. Leaves me with a great finish and is super easy to wipe off. By far the easiest thing I've used to wipe off in direct sunlight.
Today, I left Speed on and topped with Poxy. Seemed to work nicely together. Gloss is very good! This was on an '04 Odyssey with 140k miles.
Rob
That is great to hear.
