Hazy on Plastic Speedometer Gauge Glass
gravymatt
Hi Folks,
I have used the regular lineup of Windex, LCD screen cleaner, Method Glass cleaner, I can't get the haze of the clear plastic of my Speedometer Gauge see pictures.
Any suggestions of next products to use, the haze is kinda weird cause I can use a finger nail to rub it off?
Thanks for the Suggestions,
Matt
After washing and drying the surface; use a plastic polish that is safe for all types of clear and coloured (polycarbonate) type plastics i.e. Lexan®, Perspex, Lucite and most clear acrylics – Bay Plastics Ltd -Novus 1, 2 & 3
Novus 1; Plastic Clean and Shine - gently cleans all plastics without scratching, leaves a lustrous shine that resists fogging, repels dust, and eliminates static.
Novus 2; Fine Scratch Remover - removes fine scratches, haziness, and abrasions from most plastics (exceptional for removing scratches from Plexiglas). Use repeatedly and restore faded and discoloured plastics.
I would probably start out with Meguiars PlastX, easy to use, cheap and you can find it at any store that sells automotive products. If fast, cheap and easy doesn't work, you'll have to start working your way up the list of applicable, maybe not so available products.
