In two areas on my '05 Z4, I have "bubbling" vinyl...with no reasonable explanation. What is "bubbling" vinyl, you ask? Well, it appears that my tan interior vinyl, is really a fine coating of tan vinyl over the tannish plastic base. This thin covering of vinyl is now bubbling and peeling off the plastic structure that it is on. And, there appears to be no way to stop it or repair it.
What makes this interesting is that the two places that are bubbling, are not really high wear areas. One place is the vertical door frame to the left of about where the driver's left shoulder is. It first bubbles and then a very thin layer of vinyl peels off showing the plastic base. The other area is the plastic console just below the aluminum trim that outlines the console. It doesn't appear that the vinyl was glued on but rather "heat-shrinked" on.
My only thought as to why this is happening is that it may be related to the use of sun-screen lotion. I live in SoFL and play a lot of tennis. I also have had quite a few skin cancers, so I use a sun-screen lotion. The damn lotion does impart a yellow stain on the tan leather and I'm wondering if it it the cause of the bubbling, too. Although, the two areas where the bubbling occurs, doesn't seem to be where contact would be made with the lotion, nor does the vinyl areas where lotion makes contact show any staining?
Another forum replied that BMW became aware of this with the '06 330i
