[I'm thinking that, if the clear vinyl is an air-tight seal, it would keep out oxidation/pitting/yellowing, although I have no evidence of this.]
Ultra violet radiation degredation comes from UV light penetration, so an air-tight seal won't help
Before UV light can cause harm, it must first be absorbed. If it is not turned into heat or transferred to a nearby stabilizer molecule called a quencher, it breaks weak chemical bonds. This is the beginning of UV damage; some materials absorb UV light more readily than other materials. Materials that readily absorb UV light are quickly damaged...rubber, vinyl, gel coat fibreglass, and many other plastics.
For UV protection use 303 Space Protectant
Headlight Protection
Acrylic is slow to absorb UV light and accordingly very resistant to photo degradation. Protect your expensive headlamps, before it's too late. LampGard?, an incredibly tough 40 mil thick, double-polished urethane material that is optically clear and applies (peel & stick) directly to the surface. This product has built-in ultraviolet inhibitors that help prevent the material from drying, hardening or discolouring. We custom die-cut to fit your specific vehicle for a precise, perfect fit, it comes with easy-to-follow instructions and applies to headlamps, fog lamps, turn indicators and parking lights (when applicable) to protect them from scratching, cracking and pitting.
LampGard?
An extract from one of a series of in-depth detailing articles ? TOGWT ? Ltd Copyright 2002-2008, all rights reserved
