04 white Yukon front door about 13 inches it starts out in the clear then into the paint and then back out to the clear it did not get into the metal what do you guys recommend, Thanks. Dave
Sorry to hear of your vandalism I would first try a polish by hand and follow the scratch line. You are basically trying to level the outside edges of the scratch to the same level as the scratch. After you have made the scratch look the best you can by hand, then use your pc to make the whole panel look clean and have an even look to it. Good luck.. you also might want to post a picture to give us a better idea of what you are dealing with
