Hand or Pad
Ronkh
Wax Waster
Ok folks, I'm gettin the urge to waste some wax....... :yay
So when I get a night where people are not getting sick or injured it's time.
So do I want to do it by hand or applicator pad?
It sounds so exotic doing it by hand. Any pro's or cons?
I could never get it to work right using my hands. Too much wax here, no wax there. I think with a pad I get more uniform coverage, and by using a pad I can use the Flex or PC to apply.
I've done most of my sealants by machine, never wax. Mebbe I should try that too.
Here's what I posted on this about a year ago on MOL here,
It's a marketing strategy about creating the perception of;
  • Unique
  • Special
  • Exclusive
  • Reserved
  • Aristocratic
  • Fill in the blank
Back in about 1991 I actually waxed a car that I had buffed out first by machine, (rotary buffer), and then bare-hand applied two coats of M26 Liquid wax. That is I used my bare hand to apply the wax. I mostly did this to see what it was like, to see if there were any benefit to using your bare hand to apply a wax to the paint on a car.
In my opinion, for whatever that is worth... there was no benefit at all..
At least no benefit that made it better than using a normal, foam hand wax applicator pad or a foam buffing pad on a machine. I have never used my bare hand to apply a wax to a car since then and I've worked on a lot of cars. A foam wax applicator pad can absorb, in this case absorb some wax, (or a paint sealant), and then when you press on the foam just a little it will release some product enabling you to spread it out. You skin can't absorb and hold a little wax, (or paint sealant), like a quality foam applicator pad and so pressing on your skin, or pressing your skin against the paint won't release any wax or paint sealant, you have to go back to the source and get some more wax or paint sealant back onto your hand to continue spreading product.
There was one tiny benefit to applying wax with a bare hand and that was using your sense of touch if you sensed or felt any kind of particle between your hand and the paint you could stop and remove the offending particle. Not sure I've ever seen this pointed out by any other forum personality that practices bare-hand waxing? With an applicator pad you can't feel tiny particles, you have to turn your applicator pad over often and visually inspect for them and this by the way is a good habit to forum or "Best Practice" when applying any paint care product by hand or machine.
In a perfect world, the best way to apply a wax or a paint sealant to paint is without a doubt by machine, specifically a dual action polisher with a soft finishing pad or a polishing pad on the 3-4 speed setting after the paint has been previously cleaned and polished.
Spreading the pressure out
Bare Hand
When you're working with your bare hand, there's no interface to spread pressure out, just your hand against the paint.
DA Polisher
With a machine like a Dual Action Polisher, the pressure is spread out evenly over the entire face of the buffing pad assuming you're using good technique and holding the pad flat to the surface.
Wax Applicator Pad
Your hand, which is actually 4 fingers pushing down on an applicator pad creates pressure points and cannot match, let alone outperform the equal pressure applied to the entire face of a foam buffing pad with about a 6" diameter by machine.
Picture courtesy of MeguiarsOnline.com
So out of the 2 options, machine, wax applicator pad or bare hand, the machine option provides for the most even pressure when spreading out a wax, hand application offers some ability to spread out the pressure but when working by hand there's nothing to act as an interface between your hand and the paint.
A Romantic Idea
Melting wax with your hand is just a romantic idea, nothing wrong with that as it does invoke this perception of old world craftsmanship. That said, you can melt most paste waxes enough to liquefy them so the wax will flow into your applicator pad simply by spinning your applicator over the surface of the wax while it's in the can. M16 has been out since 1951 and all the old-timers knew this back in the day...
If applying wax with your bare hand sounds like a good idea simply get a clean, foam applicator pad and then do your own hands-on test and try applying and spreading out a thin, uniform coating using both methods, hand and applicator pad and then come to your own opinion and then post it here to share with others.
And here, back in 2006
For the record and for what it's worth, I've used my bare hand to apply a wax to a car I machine cleaned and polished using the rotary buffer first, so the finish was absolutely clean, smooth and free of any defects. This was back in 1991 in Bellevue, Washington at a shop called, "Urban Logic".
I did it to see what it was like as compared to what others have said and what I've read because some people/companies have recommended this method to apply their products.
While I didn't see any real harm in the process, a soft foam applicator works better because the physics of the foam allow it to hold product inside of itself, that you can then release as you press gently against the paint as your moving the pad over the finish.
You skin on the other hand only holds a small amount of product on the surface, [of your hand and fingers], creating a disadvantage when compared to the foam applicator pad for applying wax effectively and in a timely manner. Just my humble opinion, but given the option of applying wax by bare hand nor with a foam applicator pad, I would choose the applicator pad hands down... no pun intended...
If you pay attention, you can feel if any abrasive particles enter into the process because of your sense of touch, so that's a real benefit but if you're working clean and using good technique then this shouldn't be a factor anyways.
I will say that to advertise, or market your services to your customers and to tout that you apply your wax using your bare hand holds some mystique or air of elite professionalism/craftsmanship to it, (but only to the uneducated in the art of polishing paint).
My honest opinion... no benefit at all to apply any type of wax or paint sealant using only your bare hand.
I would take a simple, clean, soft foam wax applicator pad every time no questions asked, no doubts about the end-results.
Of course, reading about it is second-hand knowledge, the best test is to try it yourself and get first hand knowledge on the topic and decide for yourself if there is any true benefit to applying a wax with your bare hand or if this is just a form of marketing.
Thanks Mike.
Just to note the last paragraph of my above post...
Just for fun sometime, try it yourself and see if your experience is similar to what I describe in my comments. First hand knowledge, no pun intended is one of the best ways to make up your own mind about a topic like this.
One day........ But it won't be on the black car.
Besides the uniqueness of hand application I only see 2 benefits. First as you said, you caould feel something on the paint that you might not feel with the pad. Second you could get into smaller areas. For smaller areas I could just use a finger anyway.
I am starting to get interested in using the pc for wax application. I've only used it for sealants in the past.
When LC came out with the red 4" pads I picked a few up from AG. Ever since then I tend to use them with the PC over the hand method. I've never had any swirl or marring problems even on BMW JB. I've used 476, NB, and NR with the PC. NR I find is the easiest to use with this method. No knives needed to spread the wax onto the pad. I know you have tubs of NB and NR so you should have no problem dipping the PC in to grab some wax. :rockon
I remember Beercan (Rich) was using the PC to spread Natty's on his black Dakota at the summer PB Detail weekend. He prefers the PC method over hand also.
I also got a 2.5" backing plate for my pc. That way I can use a normal sized mf pad and put the pc down on it. Saw that done and it looked interesting.
How did you know I got wax? :notme:
