Klock
Hey guys! I have finally gotten to polishing my personal vehicle! The only thing is that it has taken me 2 weeks to do a basic 2 step.
I am going to coat it with exo v2, and I have panel wipe for the final prep before applying the exo v2. I used menzerna 4500 for the final step, and didn't use panel wipe directly after finishing each panel, so now I have some places that have had polish residue on them for up to two weeks.
My question is will it be harder, Easier, or the same effort to remove ALL of the polish residue now that it has sat on the paint for so long? Should I use the same tecknique with the panel wipe, or adjust the amount of product used, or passes over the area in order to remove it all?
There are a lot of times where I will wash the car after polish, and before lsp. Then do panel wipe, or iPa if I'm using a coating. But With my time constraints I'm not going to be able to wash it again for a wile.
Also. If I was to layer exo with exo. What would be the prime time to do so? Directly after applying the first coat, or after its cured, or sometime in between? This will be my first time using exo v2 so any tips will be very much appreciated.
Thank you.
Thank you.
