I just wanted to post an FYI for any of you who may be thinking about ordering or have ordered the latest Green Polishing pads from LC.
A few weeks ago I reordered some CCS 6.5 inch Green Polishing/Finishing Pad - LC-78-34650DA.
I also ordered the CCS 6.5 inch Green Cutting Pad - LC-78-Coarse.
However, as I worked the other day I reached for a new Coarse pad and as I went to open it, I noticed it simply had the same product code as the Finishing Pad. I compared the two and found that the finishing pads' cell structure was tighter, the green was more minty, and the packaging said Finishing on it. But, I wanted to be sure.
I contacted Autogeek to inquire about whether or not I had indeed received the correct pads. They confirmed it in a phone call and then an email. The ones that read FINISHING are indeed what they read and the COARSE version only has the product code. The new batch of COARSE pads will soon ship with the corect packaging, but I guess they produced these before the FINISHING version and wanted to use up all of the packaging first. If you do end up buying the two versions, you may want to label which is which because the colors are SUPER similar.
In case I confused you, here's the email from Penny at AG....they are always very helpful:
"Hi David
I can definitely see why you are confused. Hopefully, this will help. The ones that are the finishing pads should actually say that right below the part number. Also, that part number with has CCS on the end. The coarse ones will just have the part number underneath they say Patent Pending Worldwide and Made In USA. The next round will have the part number that says coarse in the description.
Please let me know if I can help you with anything else.
Best Regards
Penny
AutoGeek.Net
Customer Service
-----Original Message-----
Sent: Tuesday, February 03, 2009 6:35 AM
To: [email protected]
Subject: autogeek.net Inquiry
First Name: David
Last Name: Bibiloni
Email: [email protected]
Confirm Email: [email protected]
Order Number: 487234-1
service: on
Inquiry: I was checking my order the other day and I noticed
that I have 6 LC-7834650DA green polishing/finishing pads. 3 of them say this exactly on the plastic and the other 3 only have the part number. I didn't get any that say: LC-78-COARSE. The three with only the part number do seem to have larger foam pores, but ,again, does not say COARSE on the packaging. Can you help me figure this out?"
:2thumbs:
"Hi David
Best Regards
Penny
AutoGeek.Net
Customer Service
First Name: David
Last Name: Bibiloni
service: on
:2thumbs:
