Jngrbrdman
I found this on another site and thought I'd share. If you want to save the files after you listen to them then you can. To avoid offending those with sensitive ethics regarding 'stealing' music, I've made it harder to see the instructions on how to do it. It isn't really stealing music if they are putting it on your computer themselves though, so you really don't need to worry too much about it. Either way it is a good site for listening to music while at work.
www.pandora.com
To save the music files...
Use the application like normal, BUT DON'T CLOSE IT, the files will be deleted.
If you are using Firefox, the cached mp3s are located here: C:\Documents and Settings\[username]\Local Settings\Temp\plugtmp-##
If you are using IE, they are here: C:\Documents and Settings\[username]\Local Settings\Temporary Internet Files
The cached files look similar to this: http://audio-eqx-sjl00.pandora.com/access?version=4&token=Nk66wifYayzFL70RJZ5OryYnBj0 m1iSvQPPe5MPTrCFQte%2FGug0d4rWLQH0mK21M5sKHWV8TgTD N8hcEUMSwcoqwUVcJrj1DL2LW6%2ByW5fLVbQxZl6tlepr0AEV kVZBrRcg7CS2aDmZCqx24lSG8sGFp5jOc2JFQhVd91iHWdfUNJ kiFbGsbwn%2FH1jPPSHrmHQ9j0ZyB%2BPc%3D&lid=5037074
Copy them out and rename them. 128kbps, no the id3 info does not come along.
It will be fun for about 10 minutes before they figure out the loophole and close it, but until then it is a great way to fill up your computer with music.
Enjoy.
www.pandora.com
Enjoy.
