Good deal? PC 7424
dfw
He is selling (2) for $100 each. They are brand new and never opened. Not sure what the going price is now at a reputable site, so just asking.
The PC is a good starter tool, however I'd also suggest considering the Ridgid 2611 from Home Depot. It already comes with a 6 inch backing plate and has a higher OPM range of 10,000 for $129. It comes with a 3 year warranty and they offer a lifetime warranty option when registering it(send a copy of your receipt). The only downside is that you have to use 6.5 inch pads with it.
So theres no way to swap out the BP ? I remember Zoran mentioning it before he left......
If you can find the older 2610 it has the same single screw type design as the PC and a PC backing plate should work. The aluminum housing is rather large so the 6 inch backing plate is the safest option. The 2611 has 4 holes for mounting the backing plate. You might be able to find another brand backing plate to fit but again the housing size is such that a 6 inch plate is safest. Stop by a Home Depot and you'll get a better understanding.
Here's the specs...
R2611 Cat #23963
Features
Dual random orbit settings – for fine finish and aggressive material removal
Electronic speed control – 4,000–10,000 r/min.
Soft Start and integrated pad brake control – for a gouge-free workpiece
Auto-stop brushes – for extended motor life
Micro Fiberâ„¢ hook and loop pad – fits snug for improved sanding efficiency
On board vacuum adaptor – for 1-1/4 in. and 2-1/4 in. vacuum hose
Specifications
Input: 4 Amps.
No Load Speeds: 4,000 - 10,000 r/min
Orbit Diameter: 1/4 in. and 1/8 in.
Tool Weight: 6 lb.
R2611
BTW 1/4 inch =6.4mm oribit
Home Depot stocks a Ryobi 5 inch backing pad with 4 mounting holes. The holes lined up with the holes on the 2611 so I believe it will work.
I recently bought a rigid 2611, and tried out a larger pad,seemed to work o.k. I wondered if there was any specific reason I should use only 6.5 inch pads with it
