Going to try Poorboys need some help
Beason
Well I have been trying to achieve a good shine on my black tahoe, but am having problems getting rid of swirls/scratches. Im not achieving the desired results with Speed Glaze so I think I may switch to a more user friendly swirl remover. I was going to try SSR2. How does it compare to SG? Can I go straigh from SSR2 to EX or would I need something between suck as VM? Also when im short of time I was going to add Poorboys Polish w/ Carnauba as a one step wax. What type of results should I expect?
Hear are my plans starting from scratch
DACP w/ Cutting
SSR2 w/ Polishing
VM w/ Finishing
EX by hand
Routine paint care
SSR2 w/ Polishing
VM w/ Finishing
EX
Normal
VM w/ Finishing
EX
Quick One Step
PwC w/ polishing
That sound right or do I need something between ssr2 and vm?
I would say to try SSR2.5 followed by DACP both on polishing pads
2.5 breaks down real well, and it cuts through lots of problems!
DACP with a cutting pad is an extreme combo IMO. on the black, you are going to see MAJOR rotary marks (if you are using a rotary) or major hazing if you use a PC. After DACP, you will definately need a medium polish to tackle the hazing. SSR2 should take care of that but i would go with SSR1 or Menzerna FP before going to a lsp. that one extra step may not "LOOK" to be necessary, but it certainly won't hurt. using AIO before EX would be usefull as well IMO.
Vernon
I always thought 2.5 was comparable to DACP and I dont need something that strong. I want a replacement for Speed Glaze because Im not having the desired results
They are very similar in terms of cutting ability. I have more luck with SSR 2.5 for swirls and DACP for light scratches.
IMHO you may want to use a lighter polish than SSR2 such as SSR1, PwC, or a good paint cleaning lotion like the Pinnacle or P21S or Sonus. They will help to remove any marring caused by defect correction and will help to correct light defects themselves. It is generally better to try the least aggressive approach first.
If I could only buy one of the SSRs it would be 2.5. I have gone straight to a product such as AIO/VM from it, but if it is my car I'll always polish in between. SSR 2.5 may leave some minor marring, but compared to DACP I have found that it leaves less marring...just one man's experience.
VM does have some fillers however I really like the look on my silver Solara. I have topped it with EX-P, but not EX. PwC is a great base for EX and it looks very good as a 1 step product; I use it in my door jambs as a 1 step currently. Some people have expressed concerns about durability when using VM due to the oils it contains; to date I have been very happy with it...
I'm sure you'll get lots of feedback on VM + EX. If memory serves me correctly I believe that JDookie uses that combo on black and his Expedition always looks great. I'll do a search and check.
One note...PwC would remove most of the EX you had on your vehicle. You may be better off adding a second or third layer of EX than removing it with the PwC...
too bad the pictures came out fuzzy - So much for "auto" focus, but it was my fault.
I detailed a black 2002 Tahoe.
Look for my post in awhile.
As far as #80? I'd guess you are using too much. It is an excellent product. Use less of it, and go slow. THat is the fastest way to get good results. m2c.
in my experience, Speed Glaze was good at removing light swirls. i haven't tried using my SSR 2 for that purpose but i think they're similar in cutting power. i think you might like the results of SSR 2.5 better though as it seems to remove swirls quicker and better.
i would get a polish to between SSR 2.5 and EX and like how SSR 1 worked for me. you can substitutes PwC for SSR 1 if you want. sometimes using SSR 2.5, i can go straight to LSP. other times, i get some hazing which SSR 1 cleans up nicely. VM is good in that it adds a little more gloss and shine before sealing it up with EX.
I agree 100%!! :xyxthumbs
A good combo I have personally used is:
SSR 2.5
PwC
EX or EX-P depending on color
SSR 2.5
PwC
make that X 2!
ssr 2.5
PwC
FK1 Sealant
Slickest combo in my experience. (pwc+fk1)
On black I like the look of SSR2.5 (if needed), then VM topped with EX. Leaves a very deep, wet look with great shine. I apply both the VM (LC white pad) and the EX (LC grey pad) by PC. Hope this helps!
