going from ssr2 directly to a sealant
III
97 bonneville/98 Z71
Can I go directly from ssr2 to ex, ex-p, natties, or do I need to follow up with ssr1 or pwc first? If I need to use ssr1 or pwc before sealing, how could pwc work? Wouldn't pwc be considered a sealant since it has carnauba in it?
I'm doing this by hand.
SSR right to a sealnt is alright. I have done it many a times. It is always better, imo, to go to a SSR1 or Pw/C before the sealant but SSR2 right to a sealant looks good.
And carnuba does not make something a sealant.
97FLAIRSIDE said:
just dont do what I did and go from ssr3 to the polish.
Hope you read and answer me:
What SHOULD you have done??
Should you have gone down to ssr2 or ssr1..but what OTHER fine polish would you be able to use after ssr3 before going to the polish???
Did it the other day - SSR2 directly to Final Polish on dark blue and it looked great. Yes, you can always achieve a finer finish if you drop down to a finer SWR, but I didn't personally feel it necessary. I was applying the SSR2 with a PC and a white polishing pad and there was no hazing whatsoever. Perhaps with a cutting pad there would have been some hazing so you would have to go with SSR1 or ProPolish.
