We all know what brake dust can do to wheels: pitted metal and a dull, lifeless finish. The question is, how do you remove brake dust from intricate wheel designs without scratching the wheel finish? Is there a one-size-fits-all wheel brush? Yes, there is. The Daytona Speed Master Wheel Brush goes where no wheel brush has gone before because it flexes like no other brush. If your vehicle’s wheels are tough to clean, you owe it to your car to get the Daytona Speed Master Wheel Brush.
The Daytona Speed Master Wheel Brush is made for metal. It features nylon Nylex bristles that are flexible, durable, and completely non-abrasive. The end of each bristle is feathered to provide an extra gentle touch on delicate wheel finishes. Use the Daytona Speed Master Wheel Brush on highly polished aluminum, chrome, stainless, clear coated, and painted wheels with confidence. This brush will not scratch!
The Daytona Speed Master Wheel Brush cleans the entire wheel, front to back. The memory bristles flatten against the stem to squeeze between narrow spoke designs.
Detail brushes can lose their shape and their functionality over time because they’re pressed into the grooves and crevices of your car. The Daytona Speed Master Wheel Brush has patented memory bristles that regain their shape after every use. Simply rinse the brush in hot water and hang it upside down to dry. The bristles will settle back into their original shape, just like new. Memory bristles allow the Daytona Speed Master Wheel Brush to remain effective when other brushes fall short.
The synthetic bristles are chemical resistant so you can use any kind of wheel cleaner without harming the brush. (Your wheels might not be so lucky! Stick to a water-based wheel cleaner recommended for all wheels for the best results.)
The Daytona Speed Master's bristles flatten against the stem, allowing it to clean between the wheel and brake caliper!
The Daytona Speed Master Wheel Brush may look like a big brush, but it fits in the smallest spaces. Clean between wire spokes and even between the brake caliper and the wheel! The flexible bristles easily fold against the stem to a ½ inch thickness. The brush works just as well for wide-set spokes.
The Daytona Speed Master Wheel Brush cleans from one side of the wheel to the other. The upgraded, vinyl-coated wire stem flexes to reach all the way through the wheel to clean the edge on the other side! The 13 inch stem is of a heavier gauge wire to give it flexibility and stability. The vinyl coating protects the wheel from scratching. If you pull the bristles apart, you can see that the wire stem is completely covered for the entire length of the brush. The tip of the brush is bonded in vinyl to protect the wheel from scratching.
Clean from one side of the wheel to the other with the 14 inch Daytona Speed Master Wheel Brush.
The Daytona Speed Master Wheel Brush cleans up under the hood, too. The flexible brush easily cleans in all the nooks and crannies, and the soft bristles will not scratch chrome, aluminum or painted engine components.
If you’re looking for a wheel brush that genuinely makes cleaning easier, you need the Daytona Speed Master Wheel Brush. It’s the only brush that flexes to fit any wheel design and regains its shape after every use.
The Daytona Speed Master Wheel Brush is available from Autogeek.net.
